What is the usage of the second coax connector?
Postby BlueSky » Fri Jul 31, 2015 10:17 pm
I notice there are two coax connectors on this tuner card. Does this mean that there are two inputs that can be split among antennas? In other words, could you have an antenna pointed in one direction connected to two tuners, and an antenna pointed in a completely different direction connected to the other two tuners, which would be very useful in some situations? Or is the second connector for some other purpose?
BlueSky
Re: What is the usage of the second coax connector?
Postby crazycat » Sun Aug 02, 2015 7:10 am
1 RF IN + 1 RF OUT
Postby Pierrerol51 » Sun Feb 12, 2017 3:58 am
Tis is my first time posting, good day to all the members on this forum'
I'm located in North America using TBS 6704 with Tvheadend for antenna channels. It seems like I can't scan satellite dish channels. I have been told, that I need a TBS DVB-S2 TUNER.
Can any one recommand the one for the Unites states . I will be using ,Dish Network.
Thanks,
Pierrerol51
Postby steven » Tue Feb 28, 2017 4:33 pm
Hi Pierrerol51
For normal DVB-S/S2 signal you can try TBS6904
Return to ATSC/ Clear QAM Quad Tuner PCIe Card TBS6704
