Flussonic now displays signal and SNR levels what are they?
Postby wa4zlw » Sat May 21, 2022 3:41 am
The latest codebase from Flussonic now displays SNR and signal levels. They display it as a percentage and when I asked them specifically if dBm or mV they were evasive. They first sent me to kernel.org and both of those links showed deprecated values. Then this:
>> but it would be nice to know what that "raw" RF number is related to dBm or mV
It depend on DVB card supplier and driver, which we don't programming.
They display two set of numbers for a specific value as well and the numbers seem to vary widely.
ber
0
has_carrier
true
has_lock
true
has_signal
true
has_sync
true
has_viterbi
true
snr
65505
snr_raw
-20341
strength
35
strength_raw
23580
Anyone have any ideas what these values mean and what the units are?
Thanks leon
wa4zlw
Re: Flussonic now displays signal and SNR levels what are th
Postby crazycat » Thu May 26, 2022 8:10 pm
look like legacy DVB API v3 SNR, Strength values (16-bit raw value, usual 'scaled' 0-100% value)
Postby wa4zlw » Fri Sep 30, 2022 2:35 am
hi there...is there anyway to get real SNR and signal strength out of the cards?
Leon
wa4zlw
Return to ATSC/ Clear QAM Quad Tuner PCIe Card TBS6704
