TVHeadend don't stop finding services
Postby bpbastos » Wed Apr 01, 2015 8:43 pm
My tvheadend installation don't stop finding services, right now I have exactly 8855 services and if I go look tomorrow, it will be twice as that.
I've already opened an issue at tvheadend's bug track (https://tvheadend.org/issues/2740#change-12853) but it seems like the problem could be related to the drivers.
According to tvh support this behavior usually happens when the drives do not flush the buffers from previous tuning correctly.
Here is the transcription from tvh issue ticket:
"I saw this behaviour when the linuxdvb driver (kernel driver) do not flush the buffers from previous tuning correctly, so data from previous mux were received and tvh parsers were confused, because they had information "hey, the current mux has these services", but it was not true. There is option in the tuner settings like "multiple tuning". You may try it. Eventually, you may discuss this with the driver author."
Is there a 'multiple tuning' option for the 6205?
Any help would be welcome.
Thank you
bpbastos
