WMC Cant find any tv signal
Postby Yamiraan5 » Mon Jul 08, 2019 2:10 am
HI
im newbie and just want to watch sky UK channel on my PC, i bought TBS6205 and connect satellite cable direct to the card, and start setup with WMC, Tasks > Tv > Setp Up TV Signal > entered my postcode and agreed with condition, after download guide start Examining Tv Signals but after complete search im getting this message that WMC is unable to find any tv signals,
what im doing wrong? i bought this card from amazon uk but there is not guide for new peoples, i found this that these type of the card is only for professional, i just want to ask here before i sending back, hope someone help me
any help will be really appreciated
note: tuner card driver installed successfully ss is attached
Yamiraan5
Re: WMC Cant find any tv signal
Postby steven » Tue Jul 09, 2019 9:41 am
What about your signal ? DVB-S ? satellite cable ? for 6205 it is DVB-T/C tuner card can not receive the DVB-S signal
For DVB-S signal you need to use TBS6904
Postby Yamiraan5 » Wed Jul 10, 2019 5:14 am
Thanks a lot Steven
is there any guide how to use this card?
i only watch and record some tv programmes on my computer, so with this card 6205 i cant do that? i know these are very basic question but this is not my field, if i connect this card with my sky box will this work?
Regards
Yamiraan5
Postby steven » Fri Jul 12, 2019 9:49 am
here is the 6205 user guide
https://www.tbsiptv.com/download/tbs620 ... _guide.pdf
and if you want to receive the DVB-S/S2 signal you can check the TBS6904 card :
https://www.tbsiptv.com/tbs6904--dvb-s2 ... -pcie-card
