TBS6290 does not find DVB-T2 channels
Postby pstumbler » Tue Nov 17, 2015 2:07 am
my recently purchased TBS6290 does not find any DVB-T2 channels under Linux Ubuntu.
When I put it into my Windows7 machine it works correctly and finds all my T and T2 channels with DVBViewer. Also descambling the scrambled channels with the CI works fine.
My Linux system:
pstumbler@SERVER:~$ uname -a
Linux SERVER 3.19.0-33-generic #38~14.04.1-Ubuntu SMP Fri Nov 6 18:17:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
I use the latest TBS drivers "tbs-linux-drivers_v151105.zip" which are installed correctly - see my other post: http://www.tbsdtv.com/forum/viewtopic.php?f=169&t=9621
Ouput from scan-s2:
pstumbler@SERVER:~$ cat at_all.scan-s2
# T freq bw fec_hi fec_lo mod transmission-mode guard-interval hierarchy
T 490000000 8MHz AUTO NONE AUTO 8k AUTO NONE
T 618000000 8MHz AUTO NONE AUTO 8k AUTO NONE
T 682000000 8MHz AUTO NONE AUTO 8k AUTO NONE
T 514000000 8MHz AUTO NONE AUTO 8k AUTO NONE
pstumbler@SERVER:~$ sudo scan-s2 ./at_all.scan-s2
API major 5, minor 3
ERROR: Cannot open rotor configuration file 'rotor.conf'.
scanning ./at_all.scan-s2
initial transponder 490000000 8MHz AUTO AUTO AUTO 8k AUTO NONE
initial transponder 618000000 8MHz AUTO AUTO AUTO 8k AUTO NONE
initial transponder 682000000 8MHz AUTO AUTO AUTO 8k AUTO NONE
initial transponder 514000000 8MHz AUTO AUTO AUTO 8k AUTO NONE
----------------------------------> Using DVB-T
>>> tune to: 490000:I999B8C999D999M999T8G999Y0:T:27500:
DVB-T frequency is 490000000
DVB-T bandwidth is 8000000
WARNING: >>> tuning failed!!!
>>> tune to: 490000:I999B8C999D999M999T8G999Y0:T:27500: (tuning failed)
>>> tune to: 618000:I999B8C999D999M999T8G999Y0:T:27500:
DVB-T frequency is 618000000
>>> tune to: 618000:I999B8C999D999M999T8G999Y0:T:27500: (tuning failed)
>>> tune to: 682000:I999B8C999D999M999T8G999Y0:T:27500:
DVB-T frequency is 682000000
>>> tune to: 682000:I999B8C999D999M999T8G999Y0:T:27500: (tuning failed)
>>> tune to: 514000:I999B8C999D999M999T8G999Y0:T:27500:
DVB-T frequency is 514000000
>>> parse_section, section number 0 out of 0...!
0x01F4 0x2775: pmt_pid 0x0000 ORF -- ORF1 (running)
0x01F4 0x2780: pmt_pid 0x0000 ORF -- ORF2 St (running)
0x01F4 0x2788: pmt_pid 0x0000 ATV+ -- ATV (running)
0x01F4 0x2794: pmt_pid 0x0000 ORF -- ORF2 B (running)
service_id = 0x2775
pmt_pid = 0x1F5
service_id = 0x2780
pmt_pid = 0x1F6
service_id = 0x2788
pmt_pid = 0x1F8
service_id = 0x2794
pmt_pid = 0x1F7
  VIDEO     : PID 0x139C
  AUDIO     : PID 0x139D
  AC3       : PID 0x139F
  OTHER     : PID 0x13A0 TYPE 0x06
  TELETEXT  : PID 0x13A1
  OTHER     : PID 0x1CF2 TYPE 0x05
  OTHER     : PID 0x1CF3 TYPE 0x0B
  VIDEO     : PID 0x1392
  AUDIO     : PID 0x1393
  AC3       : PID 0x1395
  OTHER     : PID 0x1396 TYPE 0x06
  TELETEXT  : PID 0x1397
  VIDEO     : PID 0x139C
  AUDIO     : PID 0x139D
  AC3       : PID 0x139F
  VIDEO     : PID 0x13B0
  AUDIO     : PID 0x13B1
  TELETEXT  : PID 0x13B5
  OTHER     : PID 0x13B6 TYPE 0x06
  OTHER     : PID 0x1D10 TYPE 0x05
Network Name 'ORS DVB-T StB'
dumping lists (4 services)
ORF1;ORF:514000:I0B8C999D999M16T8G999Y0:T:27500:5010:5011=ger;5013=ger:5015:0:10101:8232:500:0
ORF2 St;ORF:514000:I0B8C999D999M16T8G999Y0:T:27500:5020:5021=ger;5023=ger:5025:0:10112:8232:500:0
ATV;ATV+:514000:I0B8C999D999M16T8G999Y0:T:27500:5040:5041=ger:5045:0:10120:8232:500:0
ORF2 B;ORF:514000:I0B8C999D999M16T8G999Y0:T:27500:5020:5021=ger;5023=ger:5025:0:10132:8232:500:0
Done.
The channels found are all in DVB-T and on transponder 514 MHZ. All others which are found by WIndows the Linux system cannot tune to...
Also the program tells me all the time "Using DVB-T" - but the channels are T2!
pstumbler
pstumbler
Re: TBS6290 does not find DVB-T2 channels
Postby crazycat » Tue Nov 17, 2015 3:13 am
T2 490000000 8MHz AUTO NONE AUTO 8k AUTO NONE
T2 618000000 8MHz AUTO NONE AUTO 8k AUTO NONE
T2 682000000 8MHz AUTO NONE AUTO 8k AUTO NONE
Postby pstumbler » Wed Nov 18, 2015 2:44 am
Thanks crazycat - but no success.
The actual program delivered with the TBS media build does not support using "T2" at the beginning of the line (ony "S", "S1", "S2").
I changed the source a little bit to use only T2 but still no channels.
Do you know any scanning or tuning program under linux, which supports T2?
I tried dvbv5-scan, dvbv5-zap, w_scan and - of course - the scan-s2 and szap-s2 but doesn't work...
Will there be a newer driver from TBS which will support the newer MEDIA API 5.10 - because the 5.3 is rather old.
Is there any BETA version in development which can be testet for T2?
Thanks!
pstumbler
pstumbler
Postby crazycat » Tue Dec 22, 2015 7:32 am
Postby koho973 » Tue Jan 05, 2016 10:13 pm
Hello.
Is there someone who had a problem to install a dvb-c drivers of this card?
thank you
koho973
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290
