TBS6905 and what hardware for transcoding
Postby clang » Tue May 24, 2016 5:30 pm
Hi all,
I want to build a server for streaming DVB-S2 to up to 8 clients in my LAN.
Some clients are bound to use WLAN and I think about transcoding stream for them.
Does anyone know what hardware is needed?
I am not sure about transcoding with gpu or cpu. Would I need a dedicated graphics card (with what power?) or would a good cpu already fit my needs (like Intel Core i7 with integrated graphics)?
I need to know because we start renovating our home and I need to decide if I can stream tv over network or need to plan using common coax cables and set top boxes.
Thank you.
Kind regards,
Christian
clang
Re: TBS6905 and what hardware for transcoding
Postby steven » Fri May 27, 2016 4:09 pm
Hi clang
For transcode it is not cheap ,you can have a try this free solution,
you can using tvheadend which support transcode version ,using a powerfull CPU such as i7 .
for pay solution you can have a look xtream-code soft which support transcode.
Kind regards
Postby guacharaca » Fri May 27, 2016 9:19 pm
clang Wrote:I need to know because we start renovating our home and I need to decide if I can stream tv over network or need to plan using common coax cables and set top boxes.
Install Cat 6 in your house. All my RG6 coax has been replaced by Cat 6 for the same system you have described.
guacharaca
