Device 544d:6178
Device 544d:6178
Postby nrm » Fri Jul 17, 2015 1:43 am
05:00.0 Multimedia controller: Device 544d:6178
Subsystem: Device 6905:0001
Interrupt: pin A routed to IRQ 5
Region 0: Memory at f7800000 (32-bit, non-prefetchable) [size=256K]
Capabilities: <access denied>
I'm currently trying to put this board to work. I've already updated pciids. But even in the database I can't find any 544d.
I think this board is supposed to be a sample.
nrm
Re: Device 544d:6178
Postby steven » Fri Jul 17, 2015 2:52 pm
Hi nrm
This message is ok TBS6905 success detect by your PC?
Can you tell us that which problem you have ?
Kind regards
Postby steven » Fri Jul 17, 2015 2:55 pm
Hi nrm
Kind regards
Postby nrm » Sat Jul 18, 2015 12:16 am
After updating pciids I reinstalled TBS drivers and it worked.
Using a 6280 and a 6905 all my dvb adapters were not sequentially acknowledge by modprobe. I don't think this has ever happened before.
I had to insert this rule: options tbs_pcie-dvb adapter_nr=2,3,4,5
nrm
