Lnb Unicable compatible in TBS6905 and Tvheadend?
Postby ArraY » Sun May 12, 2019 3:04 am
1-How to activate unicable-support on Linux in TBS6905?
2-Do I have to plug in only one cable to an input on the card (In what number of input would you have to connect) or do I have to buy a splitter to have four outputs and plug four cables into the card?
3-In tvheadend how do I have to configure the tuners so that the unicable system works for me?
ArraY
Re: Lnb Unicable compatible in TBS6905 and Tvheadend?
Postby crazycat » Sun May 12, 2019 7:17 am
Need 4-input splitter (with diode pass-block circuit, usual marked as satellite splitter 950-2150MHz).
P.S. TBS 6909/6909x support reception up to 8 transponders from one input (unicable or single-cable from one sat pol/band).
Postby ArraY » Tue May 14, 2019 4:22 am
And in tvheadend the config how to?
¿In parameters->satellite Config->universal lnb Only?
ArraY
Postby crazycat » Tue May 14, 2019 5:53 am
unicable 1 or 2 (as i know not finished yet in stable 4.2)
