6908 and streams from 5w
Postby joolzg » Sun Mar 22, 2015 1:05 am
I have a machine with a 6925 card in, which we cant use more than one card, so this 6908 should be a great card BUT
Installing this in a new machine and updating drivers to latest from you
Installing a special dvblast with multistream working
6925 works on 11012/30000
6908 does not
Now running dvblast shows "multistream" as being available on 6925
2015-03-20_08:57:31.85609 debug: using DVB API version 3.0
2015-03-20_08:57:31.85610 debug: Frontend "STV090x Multistandard" supports:
2015-03-20_08:57:31.85611 debug: frequency min: 950000, max: 2150000, stepsize: 0, tolerance: 0
2015-03-20_08:57:31.85612 debug: symbolrate min: 1000000, max: 45000000, tolerance: 0
2015-03-20_08:57:31.85613 debug: capabilities:
2015-03-20_08:57:31.85614 debug: INVERSION_AUTO
2015-03-20_08:57:31.85614 debug: FEC_AUTO
2015-03-20_08:57:31.85615 debug: QPSK
2015-03-20_08:57:31.85617 debug: 2G_MODULATION
2015-03-20_08:57:31.85617 debug: MULTISTREAM
2015-03-20_08:57:31.85618 debug: delivery systems:
2015-03-20_08:57:31.85618 debug: DVBS
2015-03-20_08:57:31.85619 debug: DVBS2
dvblast with 6908 does not
debug: Frontend "TurboSight TBS 6908 DVBS/S2 frontend" supports:
debug: frequency min: 950000, max: 2150000, stepsize: 1011, tolerance: 5000
debug: FEC_1_2
debug: FEC_2_3
debug: FEC_3_4
debug: FEC_4_5
debug: FEC_5_6
debug: FEC_6_7
debug: FEC_7_8
debug: FEC_AUTO
debug: QPSK
debug: FE_CAN_RECOVER
debug: DVBS
debug: DVBS2
So does the 6908 support multistream as it says on your site
Also have you fixed the 6925 problem, you CANNOT have more that one in a pc at once, which limits the work the pc can do
joolz
joolzg
Re: 6908 and streams from 5w
Postby crazycat » Mon Mar 23, 2015 4:26 am
TBS linux drivers not support MIS/PLS for new STV910-based devices (6983,6905,6908,5926)
Only stv090x-based 6925/5925/5980 support MIS/PLS (with my patches for stv090x driver).
Postby joolzg » Mon Mar 23, 2015 4:53 am
I thought MULTISTREAM was MIS
As their spec on http://www.tbsdtv.com/products/tbs6908-professional-dvb-s2-quad-tuner-pcie-card.html says
Quad tuner DVB-S2/S transponders receiving
CCM, VCM, ACM and Multi Input Stream support
and for 6925 http://www.tbsdtv.com/products/tbs6925-dvb-s2-tv-tuner-pcie-card.html
DVB-S2/S Transponders Receiving
CCM, VCM,ACM and Multi Input Stream Support
Generic Stream Mode Support
So to me they are saying MIS IS supported by both cards.
joolz
joolzg
Postby crazycat » Tue Mar 24, 2015 1:04 am
MIS+PLS supported only in windows drivers.
Postby joolzg » Tue Mar 24, 2015 3:01 am
so when will you have it in yours :-)
TBS pull your finger out please, we bought this PROFESSIONAL card to use in linux, not crappy windows
joolzg
Postby crazycat » Tue Mar 24, 2015 5:20 am
TBS not publish sources for stv091x demod driver, so you have only one way :)
How to report a problem with TBS Linux drivers
Postby joolzg » Tue Mar 24, 2015 5:42 am
done, hope they add it as soon as
joolzg
Postby Souldream » Thu Mar 26, 2015 2:08 am
crazycat Wrote:MIS+PLS supported only in windows drivers.
Then better to wait to buy Pro version for MIS ... we can not really tell that all software under windows for SAT ... is quite stable :geek:
Souldream
Postby crazycat » Thu Mar 26, 2015 3:16 am
Btw 6905 also support MIS+PLS :)
Postby joolzg » Thu Mar 26, 2015 3:29 am
6908 IS professional
joolzg
