Error compiling linux drivers
Postby garry » Fri Jun 16, 2017 3:14 am
I'm installing linux drivers as it is pointed here - https://github.com/tbsdtv/linux_media/wiki
When I do
# make -j4
I receive error:
/mydir/media_build/v4l/../linux/include/media/v4l2-ioctl.h:15:32: fatal error: linux/sched/signal.h: No such file or directory
#include <linux/sched/signal.h>
compilation terminated.
How to fix this error?
garry
Re: Error compiling linux drivers
Postby steven » Fri Jun 16, 2017 3:48 pm
Try this package :
#wget http://www.tbsdtv.com/download/document ... 19.tar.bz2
#tar jxvf media_build-latest.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby garry » Fri Jun 16, 2017 6:28 pm
When I do
# ./install.sh
I get:
./patch-kernel.sh: line 3: dpkg-query: command not found
./patch-kernel.sh: line 8: dpkg-query: command not found
./patch-kernel.sh: line 13: dpkg-query: command not found
./patch-kernel.sh: line 15: apt-get: command not found
./patch-kernel.sh: line 18: dpkg-query: command not found
make[2]: *** [apply_patches] Error 1
and then:
media_build/v4l/cxd2820r_core.c:681:18: error: 'struct gpio_chip' has no member named 'dev'
priv->gpio_chip.dev = &client->dev;
I'm using SLES. Are ther ./patch-kernel.sh for SLES?
garry
Postby steven » Sat Jun 17, 2017 8:44 pm
For SLES system we have not tesed yet , the package we tested it works with ubuntu centos .
for SLES we need to have more check
Postby Alfredo » Sat Jul 29, 2017 6:20 am
Hello
The same problem happens with OpenSuSE Leap 42.3
Is there any solution?
Thanks in advance,
Alfredo
Alfredo
Postby steven » Sun Jul 30, 2017 10:35 am
Please test with ubuntu , CentOS ,debian for OpenSuSE we need to have a check
Postby Alfredo » Mon Jul 31, 2017 1:07 am
Hi Steven
With OpenSuse 13.1, Leap 42.2 works (if I cancel in kconfig and makefile the cxd2820r modules) and it also works with Debian 8.8
Thank you
Alfredo
Postby steven » Mon Jul 31, 2017 10:00 am
Hi Alfredo
Thanks for your update : )
