frekans Signal unstable!
Postby azimli » Tue Nov 24, 2015 8:00 pm
4.9 E
12341 H 30000 3/4 DVB-S2/8PSK MPEG-4 ACM/VCM
I'm using TBS6983 tv card This frekans Signal unstable!
what should I do
azimli
Re: frekans Signal unstable!
Postby DVB » Wed Nov 25, 2015 2:10 am
This is not ACM/VCM, but Multistream (MIS). To get stable reception You have to select one MIS from two which are in use there (30 or 40). Without MIS selection card will lock randomly first or second MIS which will give unstable reception.
MIS support is available in SmartDVB, DVB Dream, AltDVB (with BDA2 engine from crazycat) and ProgDVB.
And now you're watching 8K:
KKKKKKKK
DVB
Postby azimli » Mon Nov 30, 2015 4:53 am
Thank challenge was required by the DVB program, smart blind scan settings.
azimli
