[ Moderator Control Panel ]
by slavarec » Wed Jul 13, 2022 7:41 pm
Hello!
Can you public struct definitions for properties KSPROPERTY_BDA_SIGNAL_STATUS and KSPROPERTY_BDA_DemodSTATUS like you did for KSPROPERTY_BDA_GET_MEDIAINFO in SDK? Thanks!
slavarec
by crazycat » Wed Jul 13, 2022 10:06 pm
typedef struct _SIGNALEX_INFO
INT RFLevel; // dBm
ULONG SNR10; // SNR_dB * 10
ULONG BER10e7; // BER * 10e7
BYTE reserved[60];
} SIGNALEX_INFO;
by slavarec » Thu Jul 14, 2022 1:16 am
crazycat Wrote:typedef struct _SIGNALEX_INFO
INT RFLevel; // dBm
BYTE reserved[60];
} SIGNALEX_INFO;
Thanks a lot!
P.S. Премного благодарен!
slavarec
