Using CI from one card with another card
Postby willyp » Fri Jun 15, 2018 7:28 pm
I've got a 6983 card. If I add 6290 to my PC will I be able to use it's CI slot for 6983?
If not, what are the other options?
I don't want to have anything attached with a cable outside my PC case.
willyp
Re: Using CI from one card with another card
Postby steven » Sat Jun 16, 2018 1:07 pm
Sorry that can not used by like this , for the 6290 CAM module is paired to 6290.
For your case you can have a look try with card reader with OSCAM :
viewtopic.php?f=86&t=10049
Postby willyp » Sat Jun 16, 2018 6:29 pm
Does the Phoenix reader fit into 3.5" bay?
Are there any plans to make CI extensions either for PCIe or 3.5"/5.25" bays?
Having something lying around connected with a cable is not a good option for HTPC.
willyp
