Windows 2012 R2 Drivers(solved)
Postby bardoc » Wed Nov 22, 2017 6:01 pm
Hi everybody,
Who ever worked with TBS6983 on Windows 2012 R2?
Is there a driver for Windows 2012 R2?
Last TBS-TSRecorder (V3.0.1.4) crash at startup, CrazyScan gives StartDVBEx error.
StreamReader.log:
2:38:54 - 22/11/2017 StreamReaderEx BDA Ver:1.2.4.45-commited (Nov 16 2017, 20:58:16)
12:38:54 - 22/11/2017 Log level = 1
12:38:54 - 22/11/2017 DLL_PROCESS_ATTACH hModule = 73520000
12:38:54 - 22/11/2017 CheckForDVBEx(0x00399150)
12:38:54 - 22/11/2017 Power-off LNB on exit: ENABLED
12:38:54 - 22/11/2017 SendDiSEqC use 2 repeats
12:38:54 - 22/11/2017 Default modulation: AUTO
12:38:54 - 22/11/2017 Default spectral inversion: AUTO
12:38:54 - 22/11/2017 Default pilot: AUTO
12:38:54 - 22/11/2017 Default rolloff: AUTO
12:38:54 - 22/11/2017 Preffered BDA device type: AUTO
12:38:54 - 22/11/2017 Allowed IF Freq 950-2150 Mhz
12:38:54 - 22/11/2017 Inverted LOF<6000 and >21000 Mhz
12:38:54 - 22/11/2017 Available BDA-devices:
12:38:54 - 22/11/2017 Device 0
12:38:54 - 22/11/2017 Name: TBS 6983 DVBS/S2 Tuner A
12:38:54 - 22/11/2017 Type: Unknown
12:38:54 - 22/11/2017 Index: 0
12:38:54 - 22/11/2017 Device 1
12:38:54 - 22/11/2017 Name: TBS 6983 DVBS/S2 Tuner B
12:38:54 - 22/11/2017 StartDVBEx(-1)
bardoc
Re: Windows 2012 R2 Drivers
Postby steven » Thu Nov 23, 2017 9:22 am
Do you have installed the bda patch:
https://www.tbsiptv.com/download/common/win2008_bda.zip
Postby bardoc » Thu Nov 23, 2017 4:17 pm
After installation bda patch, everything worked, thanks!
bardoc
