TBS6983 compared to 6925
Postby barnsbury » Sat Aug 20, 2016 8:58 pm
I currently have the 6925. Used mainly for feeds (I am in Europe). Signal is usually very weak and I struggle to get a decent signal all the time. I know this would be fixed with a bigger dish, but I cannot change that at this time.
Is the tuner in the 6983 better? Is it worth the upgrade? Can anyone compare the tuner sensitivity?
Very grateful for any advice
barnsbury
Re: TBS6983 compared to 6925
Postby steven » Tue Aug 23, 2016 2:47 pm
Hi barnsbury
Thanks for your interest of our product ,TBS6983 and TBS6925 both are ST chips ,for TBS6983 it is TBS6903 now ,most they are the same ,
6903 is the dual tuner ,6925 is the single tuner .
