Upgrade persistant configuration
Postby jessej » Sat Jun 11, 2016 4:31 am
I'm about to upgrade my moi again.
Are there any way of doing the upgrade without loosing the configuration? (or has it been fixed?)
It's mostly the tvheadend configuration that I am interested in.
scp ~/.hts off/on the moi?
jessej
Re: Upgrade persistant configuration
Postby jessej » Fri Jun 17, 2016 3:22 am
Honestly? No answers on such a trivial question with such an obvious need?
Tar copy of directory will preserve the access/ownership details as well, but will it be enough for hts? Or will it mess with something that needs to be "clean" or preconfigured in the .hts dir? Or does another dir need to be backed up as well?
jessej
Postby steven » Thu Jul 07, 2016 6:08 pm
For MOIPro tvheadend config it is in
/root/.hts/ folder
you can backup it first then update your MOIPro after update copy back
Return to MOI Pro
