MoiPro MOI2921 dont connect server
Postby pispi » Sat Mar 05, 2016 5:25 am
he problem is that I can not connect to the server card, I'm using the version of tvheadend HTS Tvheadend 4.1-360 ~ g0916e52-dirty.
This is the log that shows me the tvheadend:
2000-01-03 02:45:03.021 cwc: 192.168.100.3:2800: Automatic connection attempt in 2 seconds
2000-01-03 02:45:06.017 cwc: Attemping to connect to 192.168.100.3:2800
2000-01-03 02:45:06.018 cwc: Connected to 192.168.100.3:2800
2000-01-03 02:45:06.019 cwc: 192.168.100.3:2800: Wait login response: Decrypt failed
2000-01-03 02:45:06.019 cwc: Disconnected from 192.168.100.3:280
This is the log of another computer where I'm running rqcs
CONNECT **** [Fri Mar 4 14:16:40 2016] Processing incoming connection...
Checksum error on decrypted packet.
User authentication failed (unknown user: ).
DISCONNECT **** [Fri Mar 4 14:16:40 2016] Client disconnected...
User: [Unknown] | Current clients: 2
CONNECT **** [Fri Mar 4 14:16:43 2016] Processing incoming connection...
DISCONNECT **** [Fri Mar 4 14:16:43 2016] Client disconnected...
Someone could help me, I can not make connection to the server card
[root@moi /]# uname -a
Linux moi 2.6.35.14 #214 Tue Jul 1 18:01:21 CST 2014 armv5tel GNU/Linux
pispi
Re: MoiPro MOI2921 dont connect server
Postby xiaocao » Mon Mar 07, 2016 10:43 am
hi ,
tvheadend connect server using newcamd protocol ?
you should write more detail to me .
please send me the picture of the config with tvheadend .
best regards!
xiaocao
Postby pispi » Thu Mar 24, 2016 12:38 am
I already solved it apparently was a problem on the local server dns rqcs, Thanks
pispi
Return to MOI Pro
