ERR_CONNECTION_RESET / REFUSED MOIPro_V1.0.010
Postby johnnysamu » Tue Feb 16, 2016 4:04 am
Latest firmware is very good, but when you reboot MOI PRO, It´s reset the time in the operating system, and you can not log in again. It works to enter via SSH, but I want to do more, for example, watching television. in the browser, it says "ERR_CONNECTION_REFUSED" when I try to access the page for TvHeadEnd. Very upsetting. :?
MOIPro_V1.0.010
I also get the following error when I scan for channels
"2000-10-17 22:17:25.640 mpegts: 626MHz in Vedyxa scan complete
2000-10-17 22:17:25.641 subscription: 0032: "scan" unsubscribing
2000-10-17 22:17:29.172 subscription: 0030: service instance is bad, reason: No input detected
2000-10-17 22:17:29.585 mpegts: 474MHz in Vedyxa - open PID 0419 (1049) failed, dupe sub (owner 0x1a4a9d0)
2000-10-17 22:17:29.586 subscription: 0030: "192.168.0.122 [ tv-server | Kodi Media Center ]" subscribing on channel "TV4 Uppsala", weight: 150, adapter: "TurboSight TBS 62x1 DVBT/T2 frontend : DVB-T #0", network: "Vedyxa", mux: "474MHz", provider: "TV4 AB", service: "TV4 Uppsala", profile="htsp", hostname="192.168.0.10", username="tv-server", client="Kodi Media Center"
2000-10-17 22:17:29.882 mpegts: 474MHz in Vedyxa scan complete
There seems to be a problem with the live update feed from Tvheadend. Trying to reconnect...
MOI PRO freezes, and can not be accessed in the browser
:cry:
johnnysamu
Re: ERR_CONNECTION_RESET / REFUSED MOIPro_V1.0.010
Postby steven » Sat Feb 20, 2016 6:20 pm
Hi johnnysamu
Please have a try like this :
Login to your MOIPro with SSH and set the time by yourself then save to the hardware time clock.
date -s "2016-02-20 18:17:30" //settting
hwclock -w //save
after save you can reboot your MOIPro check whether is ok
Postby johnnysamu » Mon Feb 29, 2016 4:43 pm
I do not understand what is wrong. operating system's clock is now right. I have reinstalled firmware several times. But tvheadend cease inexplicable to respond, for example, after a reboot. It is possible that communicates well through ssh with Moi pro, but not through the browser to the TV headend. I can get up the website for Example update, reboot. And I can update MOI PRO. Any idea? :?
johnnysamu
Postby xiaocao » Mon Mar 07, 2016 11:54 am
hi ,
please use command " rm -rf /root/.hts/tvheadend " to delete the configuration file of the old tvheadend , then to config tvheadend via web page.
if it also has issue , you can send me a remote control by teamviewer , i will check .
you can write email to jack@tbsdtv.com .
best regrads!
xiaocao
Postby johnnysamu » Fri Mar 11, 2016 1:04 am
Now it is much more stable. it used to break down when the contact "with the live update feeds from Tvheadend. Trying to reconnect ..."
Thanks! xiaocao :D
2016-03-10 17:53:31.603 subscription: 0022: "epggrab" subscribing to mux "11389H", weight: 4, adapter: "TurboSight TBS 6991SE DVBS/S2 frontend : DVB-S #0", network: "Thor", service: "Raw PID Subscription"
Reconnected to Tvheadend
2016-03-10 17:56:21.218 eit: 11389H in Thor: invalid checksum (len 376, errors 1)
johnnysamu
Return to MOI Pro
