MOI Pro with TBS6205 and TBS6991SE
Postby lordh » Tue Jan 05, 2016 5:50 am
Hello. I have problem with TBS6205 and TBS6991SE and MOI Pro. On fw 1.0.0.7 BOX hangs randomly after 1-3 days, but streams from DVB-T and DVB-S are clean. When i upgrade it to 1.0.0.9 and run the same time 6205 and 6991SE streams from DVB-T freezes a lot. Without using 6991SE streams are clean. I tested it with dvblast and astra with the same results. I What can I do to resolve the problem?
lordh
Re: MOI Pro with TBS6205 and TBS6991SE
Postby steven » Tue Feb 23, 2016 6:18 pm
Hi lordh
Sorry about the inconvenience,just know that you are using TBS6205 + TBS6991SE ,this two card using two different PCI-E bridge ,TBS6991SE is NXP7160
TBS6205 is ECP3,MOIPro for ARM platform can not support two different PCI-E bridge ,this is the problem .
Return to MOI Pro
