Continuity counter errors
Postby iptvprivado » Tue Aug 25, 2015 8:00 pm
I am using a MOI PRO with 1.0.0.8 firmware with a TBS Quad TBS6905 and Tvheadend software, but i am getting some problems.
I can´t watch the channels properly as they constantly freezing and glitching.
I am getting this all the time: Continuity counter errors.
How can i solve this?
Another question:
How can i stream the channels over the internet to Xtream-Codes Panel?
Is there any tutorial arround here?
Kind Regards.
iptvprivado
Re: Continuity counter errors
Postby steven » Thu Aug 27, 2015 2:36 pm
Hi iptvprivado
Please input better signal for TBS6905, use quad card with MOIpro 6904 is a good choose.
and streaming to xtream-code is no problem ,the problem is the orignal bit rate is very big upload to internet is not a good choose.
you need transcode first then upload to xtream-code by internet.
Postby senkron24 » Mon Feb 08, 2016 5:38 pm
thad i hore first time
i think Continuity counter errors have nothing to do with upload or transcoding or i am wrong ?
Continuity counter errors can be hardware low signal etc.. bud nothing to do with upload or transcoing...
i have same issuse in thad with model of tbs and same tvhaedend have to found out witch one make not this problem
its not easy to found witch card with version work good its test test test and lose so match time on it
i think peaple have to think 2 times to buy mio2 pro
senkron24
Return to MOI Pro
