[ Moderator Control Panel ]
by iptvprivado » Fri Aug 21, 2015 12:28 am
Is it possible to add more RAM memory or is it possible to change the RAM memory to 4Gb or 8Gb?
Is the RAM memory DDR2 or DDR3?
iptvprivado
by steven » Fri Aug 21, 2015 11:09 am
Hi iptvprivado
Sorry that the RAM is fixed to the board you can not change it.
if you want more power full you can have a look our MOIPro-AMD which you can change the DDR as you want
http://www.tbsdtv.com/products/iptv-streamer-moi-pro-amd.htmlyou can have a chek
kind Regards
Return to MOI Pro
