dvblast with oscam ??
Postby hatster » Mon Jul 27, 2015 5:56 pm
Hi all,
is it possible to link dvblast with oscam in any way ? I want to stream UDP but with descrambling. tvheadend seems too unstable, when running after a short period with 10 streams or more, the streams start to die off and i have to disconnect clients before i can make them work again !
Thanks.
hatster
Re: dvblast with oscam ??
Postby hatster » Sun Aug 16, 2015 5:03 pm
anyone ?
hatster
Postby xiaocao » Thu Aug 20, 2015 11:41 am
hi ,
it can use dvblast+tsdcrypt+oscam , you can try. https://github.com/gfto/tsdecrypt
if dvblast and oscam run in the same device , you can use mumudbvb. mumudvb connect oscam with dvbapi protocol.
best regards!
xiaocao
Return to MOI Pro
