how i change tvheadend version
Postby cilindro » Wed May 20, 2015 5:50 am
I am looking for a stable tvheadend version and i found it, now how can install on moi pro?
cilindro
Re: how i change tvheadend version
Postby steven » Fri Jun 05, 2015 8:49 am
Hi Cilindro
First you need to use cross compile tools to compile then you can using opkg command to install the
compiled version.
Cross compile tools:
http://sourceforge.net/projects/moipro/ ... p/download
You can tell us which version you want to have a try .we can help you to compile it .
Postby cilindro » Sun Jun 21, 2015 2:30 am
Hi steven you can compile the latest version fo TVH 4.0.5. Works great on linux and wish try on moi pro. Regards.
cilindro
Postby steven » Wed Jun 24, 2015 4:55 pm
Hi Cilindro
already compile one 4.0 version
here is the opk file,please have a try.
https://my.pcloud.com/publink/show?code=XZ0EOXZPXxzJm8zDbHXsCjcsMrrFhQeBVoV
Please download it and put to your MOIPro using this command to install
opkg install tvheadend_4.0+733ffb5-1_armv7
And send your test report here : )
Postby cilindro » Thu Jun 25, 2015 3:30 am
thanks steven.
I try it before and i found a lot of bugs. I try tvh 4.0.5 on linux and works great and would like to try on moi pro.
cilindro
Postby steven » Thu Jun 25, 2015 11:18 am
Hi cilindro
Ok,we will compile the 4.0.5 for you.later will send the new package here. :)
Postby steven » Thu Jun 25, 2015 11:58 am
Hi Cilindro
Here is the 4.0.5 version fo tvheadend please have a try:
https://my.pcloud.com/publink/show?code=XZsozVZyEabBciJyOH0F3Ud3OpUS8zFX1aV
And send your test report here.
Postby cilindro » Fri Jun 26, 2015 3:28 am
thanks steven i appreciated.
cilindro
Postby cilindro » Fri Jun 26, 2015 5:54 am
TVH 4.0.5 works grate has the same bug in tv adapter like all versions 0f 4.0, dont reload the page after save settings. But works great.
cilindro
Postby steven » Fri Jun 26, 2015 5:52 pm
Hi Cilindro
Thanks for your update,next firmware we will add this support. :)
Return to MOI Pro
