how to use astra
how to use astra
Postby zhangchao » Thu Apr 23, 2015 6:10 pm
Hi All
Here is the config file of astra,this can be taken as an example.
1.config dvbs/s2
#!/usr/bin/env astra-4.3
log.set({ syslog = "astra0"})
pidfile("/var/run/astra0.pid")
require("stream")
adapter_0 = dvb_tune({
type= "S",
adapter = 0,
tp = "10988:V:27500",
lnb = "9750:10600:11700",
make_channel({
name = "hunan",
input = {
"dvb://adapter_0#pnr=28655"
output = {
"http://192.168.8.124:1234"
2. config dvbC
require("stream")
type= "C",
adapter = 0,
modulation="QAM256",
fec="AUTO",
frequency=474 ,
symbolrate =6900 ,
make_channel({
name = "hunan",
input = {
"dvb://adapter_0#pnr=22272"
output = {
"udp://239.255.2.2:1234"
3. config dvbt/t2
require("stream")
type= "T",
adapter = 0,
modulation="QAM64",
fec="AUTO",
frequency=474 ,
bandwidth="8mhz" ,
guardinterval = "AUTO",
transmitmode = "AUTO",
hierarchy = "AUTO",
make_channel({
name = "1",
input = {
"dvb://adapter_0#pnr=8901"
output = {
zhangchao
Return to MOI Pro
