Firmware update Button
Postby developer » Sun Jan 25, 2015 12:00 am
The button for update should be pressed only when firmware is to be updated right?
My Pro doesnt now stream and rtp and udp doesnt work .Another thing is when Button is released LCD shows blank screen
and it doesnt work. Only when button is pressed it boots up.
How to fix this issue?
developer
Re: Firmware update Button
Postby steven » Mon Jan 26, 2015 9:56 am
developer Wrote:Hi,
yea, only when you need to update with PC OTG cable.you need to press the update button up.
after this button press up,the MOIPro is go to update mode ,do not boot anymore.
Postby developer » Mon Jan 26, 2015 1:51 pm
But is happening in Opposite way on my box.. If button is pressed , i can do the update and after update , i removed usb and release the button But then it doesnt boot. It shows blank screen on LCD . I have to again press the button to switch it on.. Not sure whats happening now...
developer
Return to MOI Pro
