got in scan But how do i play it
Postby developer » Thu Jan 15, 2015 6:07 am
Hi ,
I used szap command line
szap-s2 -a 5 -l C-BAND -c s2.conf -n 010
status 1f | signal af5a | snr a58b | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal af4a | snr a58b | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal af6a | snr a58b | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal af4a | snr a221 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal af6a | snr a3d6 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
It keeps on repeating. It means it has got tuned or locked.
Now how do i play it in ffplay or vlc ? When i use webpage i used to get udp'://ip addres so on ..
But in this case i am not sure how to play and there are other channels . How do i play them if they are on same transponder simultatneously?
developer
Re: got in scan But how do i play it
Postby developer » Thu Jan 15, 2015 6:17 am
i got the answer szap is only for testign and tuning . It will not stream to network.
developer
Postby diabloss » Fri Jan 16, 2015 3:37 am
hello
which backend you started? tvheadend or vdr?
diabloss
Postby developer » Tue Jan 20, 2015 3:10 am
i am using dvblast to tune .Scan shows the tranponders but it doesnt show up in dvblast.it shows only first four of the transponder. Only for this transponder ,there is a problem. I wrote to support who doesnt have any solution
developer
Return to MOI Pro
