Maximum ethernet throughput
Postby nrm » Sat Dec 20, 2014 4:40 am
Has anyone tested the maximum throughput of the Moi Pro?
I'm having some discontinuities when I stream 30Mbits just from one tuner. And that's one in 8 working.
If I stream just 12Mbits, basically half of the tuner channels, everything plays ok.
dvblast output is clean in the console, but VLC gets a lot of jitter.
Is this issue solved in 1.0.0.3?
http://boundarydevices.com/i-mx6-ethernet/
Regards,
Nuno
nrm
Re: Maximum ethernet throughput
Postby wirek » Fri Dec 26, 2014 4:43 am
Is this rather a problem of vlc than moi? When I use xbmc streams are always clean.
It was written somewhere that maximum ethernet speed is 470 Mb/s in MOI.
wirek
Postby nrm » Mon Dec 29, 2014 6:58 am
VLC was playing the same channel all along, hence my question.
The thread you were talking about is the "How many channels"
I'll try and see if there are no other bottlenecks on my network.
nrm
Return to MOI Pro
