MOIPro Firmware V1.0.0.3 is released.
Postby steven » Tue Dec 16, 2014 3:43 pm
Hi All
News:
1.New WebUI more easy to use.
2.New mumudvb added CAM support
3.Add online Web update support,more easy to update in future
4.Fix some small bugs
Here is the download link:
For USB update(Please use FAT32 USB flash disk):
http://sourceforge.net/projects/moipro/files/Release/MOIPro_AutoUpdate_V1.0.0.3.zip/download
For PC update:
http://sourceforge.net/projects/moipro/files/Release/MOIPro_V1.0.0.3.zip/download
Any question with this ,just send reply here,we will answer it later :)
DVB-C, DVB-T kernel rename
Postby wirek » Wed Dec 17, 2014 2:00 am
steven,
In the update readme file it is written:
uImage-m is the kernel need to be updated.
uImage_dvbc-m is DVB-C kernel you can rename to uImage-m to update
uImage_dvbt-m is DVB-T kernel you can rename to uImage-m to update
When the kernel rename is to be used? If somebody uses >only< DVB-C or >only< DVB-T?
Without rename the full kernel is loaded with DVB-S, DVB-C and DVB-T?
wirek
Re: DVB-C, DVB-T kernel rename
Postby steven » Thu Dec 18, 2014 3:09 pm
wirek Wrote:steven,
Hi wirek
The default kernel is DVBS + DVBT ,if the user want to use DVBC need to rename
uImage_dvbt-m to uImage-m to update. :)
Re: MOIPro Firmware V1.0.0.3 is released.
Postby wirek » Fri Dec 19, 2014 3:26 am
Hi steven,
Thank you for your reply. I understand that default kernel is DVB-S+DVB-T+DVB-C and if the user wants only DVB-T or DVB-C the corresponding image has to be renamed. This could be written in the Readme file.
wirek
Return to MOI Pro
