MOIPro Firmware V1.0.0.1 is released.
Postby steven » Fri Oct 31, 2014 5:57 pm
Hi All
MOIPro Firmware V1.0.0.1. is released.
News:
1.Update to the latest kernel add TBS6984,TBS6983 cards support and more stable.
2.Add dvblast WebUI config,more easy to use dvblast.
3.Update to the latest dvblast.
4.Fix some small bugs
Here is the download link:
For USB update(Please use FAT32 USB flash disk):
http://sourceforge.net/projects/moipro/files/Release/MOIPro_AutoUpdate_V1.0.0.1-1.zip/download
For PC update:
http://sourceforge.net/projects/moipro/files/Release/MOIPro_V1.0.0.1.zip/download
Any question with this ,just send reply here,we will answer it later :)
Re: MOIPro Firmware V1.0.0.1 is released.
Postby lodale » Wed Nov 05, 2014 3:07 am
Does this new firmware support USB cardreaders with PCSC protocol in OSCAM (webif)?
lodale
Postby lodale » Wed Nov 05, 2014 3:08 am
Forgot to ask if a frmware update deletes all user settings in TVheadend (chanels and so on)? If so is the away to backup and restore the settings?
lodale
Postby steven » Fri Nov 07, 2014 5:02 pm
lodale Wrote:Forgot to ask if a frmware update deletes all user settings in TVheadend (chanels and so on)? If so is the away to backup and restore the settings?
Sorry that it will format the disk ,but you can backup by yourself.
the tvheadend config file is in /root/.hts/ folder just backup this folder.
Return to MOI Pro
