How to enable Startup in Moipro????
Postby pispi » Thu Oct 16, 2014 2:21 am
anyone know how to do Startup app, like Oscam and mumudvb???
pispi
Re: How to enable Startup in Moipro????
Postby diabloss » Sun Oct 19, 2014 2:11 pm
oscam start automatically if you tick it on the webui.
for mumudvb you will need an script (is available on mumudvb homepage)
diabloss
Postby krmlk » Sat May 28, 2016 3:10 am
diabloss Wrote:oscam start automatically if you tick it on the webui.
I think there is not any startup script for centos
krmlk
Postby ly3nml » Tue Jun 21, 2016 10:48 pm
Use systemctl for startup.
ly3nml
Postby diabloss » Wed Jun 22, 2016 3:13 pm
Moi Pro simple not using centos ... it is using ARM based distro OpenPCTV
diabloss
Postby tayloirit » Tue Jun 28, 2016 6:59 am
It's not quite a clean solution but I got around this by editing "/usr/bin/moipro-webserver" and put my script files in there. So as an example, my script that mounts the NFS volumes for tv recording storage etc.. seems to work well. The moipro-webserver is the start up script that is run at startup to launch the webpage etc..
tayloirit
Return to MOI Pro
