MOI+ three questions
Postby MariuCh » Thu Jun 23, 2016 2:04 am
I have 3 questions about MOI+:
1. Is MOI+ support TBS6290SE tuner?
2. Which fimware is needed for TBS6290/TBS6290SE? Kernel DVB-S2+DVB-T2 or DVB-S2+DVB-C?
3. TVHeadend from 4.0x support CI. TVHeadend 4.1 for MOI+ is available now. Is that configuration support CI?
Regards,
MariuCh
MariuCh
Re: MOI+ three questions
Postby Jessie » Thu Jun 23, 2016 4:22 pm
The MOI+ can support TBS6290SE tuner.
The firmware don't effect the different signal (DVB-S/S2 or DVB-T2 or DVB -c).
We have the testing version (TVHeadend 4.05).If you need,you can send the mail to us(mail address:jack@tbsdtv.com).
We will supply the testing version to you.
Jessie
Postby MariuCh » Fri Jun 24, 2016 5:08 am
thank you very much for answer :)
Jessie Wrote:1. Is MOI+ support TBS6290SE tuner?
Is needed a special firmware for that?
Jessie Wrote:2. Which fimware is needed for TBS6290/TBS6290SE? Kernel DVB-S2+DVB-T2 or DVB-S2+DVB-C?
OK, but I don't understand which firmware id needed for that configuration?
http://sourceforge.net/projects/moiplus ... p/download
or
Jessie Wrote:3. TVHeadend from 4.0x support CI. TVHeadend 4.1 for MOI+ is available now. Is that configuration support CI?
Is that (4.05) version support CAM?
Regards,
MariuCh
MariuCh
Postby steven » Thu Jul 07, 2016 6:03 pm
If you want to use 6290SE as DVB-T you can using the DVBS/T package :
http://sourceforge.net/projects/moiplus/files/Release/MOI%2BV1.0.2/moi%2B_update_kernel_dvbt2_dvbs2_v1.0.2.zip/download
If you want to use 6290SE as DVB-C you can using the DVBS/C package :
http://sourceforge.net/projects/moiplus/files/Release/MOI%2BV1.0.2/moi%2B_update_kernel_dvbc_dvbs2_v1.0.2.zip/download
For tvheadend 4.1 already have CI support .
Return to MOI+
