MOI+ Tvheadend v4.2 ?
Postby ForumFan » Wed Dec 16, 2015 5:08 am
Anyone can help to upgrade MOI+ to Tvheadend v4.2
Can we expect any official update MOI+ up to TVH 4.2 from TBS ?
Now Tvheadend supports H.265/HEVC !
http://tvheadend.org/versions/59
ForumFan
Re: MOI+ Tvheadend v4.2 ?
Postby costan » Wed Dec 16, 2015 6:27 am
This is not yet officially released.
I don't think TBS will release the new version, but I'll try to provide a proper binary for MOI+.
costan
Postby ForumFan » Sun Dec 20, 2015 5:12 am
Yes you right GitHub shows last version 4.08
They finished the 4.2 development pushing over-the-air ATSC EPG code to the main repository.
The main repository is in the alpha release stage now.
The new version will be released in few weeks.
Can you provide last 4.08 version for MOI+ (published 3 days ago)
https://github.com/tvheadend/tvheadend/releases
My installation based on version 4.1.0 viewtopic.php?f=164&t=9594 is from time to time hanging up and I don't know why?
ForumFan
Postby costan » Wed Dec 30, 2015 6:43 pm
ForumFan Wrote:Yes you right GitHub shows last version 4.08
Use my 4.0.6. It should be stable, while 4.1 is not stable. On my MOI+ is working since couple of months, I had some hiccups in the past, but I had power surges so they might be related.
I'm not going to make 4.0.8 anytime soon, too much work and I want to have it stable enough (so it might have 4.0.9 or something like this).
Comparing the versions 4.0.6 and 4.0.8 there are not that much improvement (mostly bug fixes, but I think they are not impacting MOI+):
https://github.com/tvheadend/tvheadend/ ... 6...v4.0.8
When the 4.0 is not developed anymore I'll push the latest version, before trying to build the 4.2.
Ciao
costan
Postby ForumFan » Fri Jan 01, 2016 9:34 pm
I have checked 4.01 and it is really unstabile, and because this I'm looking for other stabile version
Can you pls explain me one strange behavior of 4.06.
After moved to this version my oscam is connected to socket but after running channels to descramble oscam is just waiting.
I supposed that something is wrong with my oscam but when I moved back to 3.9 oscam started to descramble.
What can be the reason this ?
ForumFan
Postby costan » Sun Jan 03, 2016 4:13 am
ForumFan Wrote:I have checked 4.01 and it is really unstabile, and because this I'm looking for other stabile version
Please post logs so we can try to troubleshoot. I used 4.0.6 with descrambling (newcamd if remember correctly) and worked.
costan
Postby ForumFan » Sun Jan 03, 2016 6:04 am
After deleting all settings .hts all works fine ;-)
ForumFan
Return to MOI+
