i cant access to tvheadend panel
Postby mikeeps2 » Wed Apr 22, 2015 8:08 am
i buy the moi plus about 4 days , but i dont know how use the tvheadend , so i try to configurate but today i can not access to tvheadend panel , i dont what happen , how i can fix that , i download the files from you web and put into the usb drive and nothing
the files are
TBS MOI+ IPTV streamer - System
TBS MOI+ IPTV streamer - Kernel (DVB-S2 + DVB-C
and the same error , i can not access to tvhead panel
mikeeps2
Re: i cant access to tvheadend panel
Postby steven » Wed Apr 22, 2015 11:35 am
Hi mikeeps2
Please have a try delete the tvheadend config folder /.hts/ .
Postby mikeeps2 » Tue Apr 28, 2015 4:46 am
hello , thanks , i write to tbs support and jack fix my problem , now enter perfect thanks
mikeeps2
Postby cilindro » Fri Jun 26, 2015 6:07 am
Can you explain how Jack fix the problem. I have the same issue after upgrade tvheadend.
cilindro
Postby steven » Wed Jul 01, 2015 10:12 am
HI all
It is the config issue.
Please have a try remove the older setting folder then try again.
rm -rf /\(null\)/.hts/tvheadend/
rm -rf /root/.hts/tvheadend/
Postby cilindro » Thu Jul 02, 2015 3:32 pm
those commands jack emailed me, i try it and did not work. Just erased some folders.
cilindro
Postby steven » Wed Jul 22, 2015 6:23 pm
Hi cilindro
Do you already fixed your issue ,if still not please contact our support#tbsdtv.com
kind Regards
Return to MOI+
