Tuner A and B not found after upgrade
Postby Hilary » Mon Apr 20, 2015 9:11 am
I did a reinstall of firmware to redo my configuration. After the install the tuners are not showing up in the configuration table. I downgraded the firmware and got tuner A and tuner B not found. Any help is appreciated
Hilary
Re: Tuner A and B not found after upgrade
Postby zhangchao » Thu Apr 23, 2015 5:51 pm
hello ,
what card insert moi+?
you can use command "dmesg | grep frontend " to find the adapter .
you can add jack_2431 by skype. or give me the remote control with teamviewer.
best regards!
zhangchao
Return to MOI+
