OSCAM SETUP
OSCAM SETUP
Postby wynasoft1 » Thu Sep 18, 2014 1:43 am
HI
can anyone explain how setup oscam in moi+ ?
thank you
best regards
wynasoft1
Re: OSCAM SETUP
Postby wynasoft1 » Sat Sep 20, 2014 4:04 am
just notice that tvheadend dont support ci module:(
wynasoft1
Re: OSCAM SETUP
Postby zhangchao » Sun Sep 28, 2014 6:17 pm
hello ,
oscam has installed in moi+, oscam's configure file is in the /usr/local/etc . oscam.conf is the config file which tells the dvb app (like tvheadend ,mumudvb ,vdr ) to connect to oscam using what protocol. oscam.server is the config file which tell how to read card from local or remote. oscam.user is the config file which tell dvb app (like tvheadend ) how to connect oscam with user and password.
Best regards !
zhangchao
Return to MOI+
