Many questions About MOI+ !?
Postby ProTechEx » Sat Aug 23, 2014 7:13 am
Hello Support Team, hello MOI+ Users,
i am new User of MOI+ and i have many questions about MOI+
I am looking for Tutorials, HowTo's and a WiKi about using the MOI+ Box, but i don't find anyting :(
I am user of MOI+ with Dual Cabel Tuner (DVB-C Tuner TBS 6680).
1. Question about VDR
I am scanning manual for VDR, and i get the Message "Scan Complete", after them i check the Button "VDR" in the Menu "Tuner Settings", but not Windows open with VDR.
How can i open the VDR GUI, is there a URL or IP ?
2. Question about Tvheadend
It doesn't Support any CI Moduls, is this Info right ? How toi conigure OSCAM to Tvheadend
3. How can i start Multicast stream ?
I have a second PC Workstation with VLC in my Network, that works as Transcoder Server. Can i get multible Streams (Channels) from MOI+ simultaneously, for simultaneously transcoding. If yes, can you tell me how can i do it ?
4. How can i add C-Line from a cccam-server ?
I read that is not posible adding directly a c-line from a cccam-server, but i read that is posible add the c-line to oscam and from there to tvheadend or VDR.
5. OSCAM
Where are the OSCAM Files, in which Folder ?
Thanks a lot.
ProTechEx
Re: Many questions About MOI+ !?
Postby diabloss » Fri Aug 29, 2014 6:20 pm
The product is quite new but stuff on the way , just some patience please. :)
diabloss
Postby oddity » Sun Aug 31, 2014 8:08 pm
RE: Question 5
The OSCAM files are in
/usr/local/etc
RE: Question 1 and 3:
There is no GUI currently see reply above. You can connect to the playlist ( eg with VLC Media Player ) via
http://{ip of your moi+}:3000/channels.m3u ( Thanks to elchubi for this ) .
oddity
Return to MOI+
