Verifying Checksum ... Bad Data CRC
Postby DVB » Tue Feb 27, 2024 10:48 am
During startup:
 _____   ____    ____
|_   _| | __ )  |  __\
  | |   |  _ \  \_  \
  | |   | |_) |  __) |
  |_|   |____/  \___/
         __  __           _____     ____   _____   ____     __
        |  \/  |   ___   |_   _|   /__  \ |  _  | /__  \   / |
        | |\/| |  / _ \    | |      __) ) |___  |  __) )   | |
        | |  | | | (_) |  _| |_    | __/_  ___| | | __/_  _| |_
        |_|  |_|  \___/  |_____|   |____| |_____| |____| |_____|
 _   _     ____              _
| | | |   | __ )  ___   ___ | |_
| | | |___|  _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
 \___/    |____/ \___/ \___/ \__|
****************  www.tbsdtv.com  *******************************************************
 ** MARVELL BOARD: DB-88F6282A-BP LE
U-Boot 1.1.4 (Jun 19 2014 - 18:58:44) Marvell version: 3.5.9
U-Boot code: 00600000 -> 0067FFF0  BSS: -> 006CFC60
Soc: 88F6282 A1CPU running @ 1600Mhz L2 running @ 533Mhz
SysClock = 533Mhz , TClock = 200Mhz
DRAM (DDR3) CAS Latency = 7 tRP = 7 tRAS = 19 tRCD=7
DRAM CS[0] base 0x00000000   size 512MB
DRAM CS[1] base 0x20000000   size 512MB
DRAM Total size   1GB  16bit width
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
NAND:512 MB
*** Warning - bad CRC or NAND, using default environment
Flash:  0 kB
CPU : Marvell Feroceon (Rev 1)
Streaming disabled
Write allocate disabled
Module 0 is RGMII
Module 1 is RGMII
USB 0: host mode
PEX 0: PCI Express Root Complex Interface
PEX interface detected Link X1
PEX 1: interface detected no Link.
Net:   egiga0 [PRIME], egiga1
Hit any key to stop autoboot:  0
(Re)start USB...
USB:   scanning bus for devices... 3 USB Device(s) found
Waiting for storage device(s) to settle before scanning...
0 Storage Device(s) found
** Can't read from device 0 **
** Unable to use usb 0:1 for fatls **
** Unable to use usb 0:1 for fatload **
(Re)start USB...
USB:   scanning bus for devices... 1 USB Device(s) found
tbs_led off ok
NAND read: device 0 offset 0x100000, size 0x400000
Reading data from 0x4ff800 -- 100% complete.
 4194304 bytes read: OK
## Booting image at 02000000 ...
   Image Name:   Linux-2.6.35.14
   Created:      2016-04-13   7:15:54 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4213384 Bytes =  4 MB
   Load Address: 00008000
   Entry Point:  00008000
MOI2921>>
And device does not load.
If I'll reflash kernel (only kernel is enough) device is starting again, but after any power outage issue is back.
Possible workaround is to keep USB drive with kernel connected, so kernel will be reflashed on every boot-up, but is there any proper solution?
I've tried to exchange LR1130 battery (it was dead), but this wasn't the reason.
And now you're watching 8K:
KKKKKKKK
DVB
Return to MOI+
