MOI+ with TBS 6504
MOI+ with TBS 6504
Postby costan » Thu Oct 03, 2019 1:46 am
Does anybody know if the brand new 6504 works inside an old MOI+?
Mine was hit by lighting and the 6285 that was inside was fryied up (like the TV on the same antenna cable, indeed). Very unlucky but if 6504 works on it, I'll spend more to have both DVB-S2 as well as DVB-T2 in the same card with 4 tuners, instead of taking just 4 terrestrial tuners with 6285 (or 6205).
Thanks and ciao
costan
Re: MOI+ with TBS 6504
Postby steven » Fri Oct 04, 2019 8:58 am
Sorry that for MOI+ the 6504 do not support it. you need to use MOIPro-AMD
Return to MOI+
