Help PLS S70smb file
Postby MariuCh » Sun Oct 15, 2017 10:02 pm
I accidentally deleted the file /etc/init.d/S70smb (I'm not sure the exact file name).
1. Can anyone attach it?
2. After restarting MOI+ does not support network - no IP on the display. I suspect the reason is to remove the above file ...
Does anyone have an idea how to add this file without resetting the device and without the RS232 cable?
Regards,
MariuCh
MariuCh
Re: Help PLS S70smb file
Postby xiaocao » Mon Oct 16, 2017 9:36 am
hi ,
you can add this file via ftp tools .
/etc/init.d/S70smb
#!/bin/sh
# samba Starts samba
start() {
echo -n "Starting samba: "
/usr/local/bin/check_net.sh &
/sbin/hwclock -w
#/usr/local/bin/lcd.sh > /dev/null 2>&1 &
#mount -t ext3 /dev/sda1 /mnt/disk
/root/checkdisk
/usr/local/samba/sbin/smbd -D
/usr/local/samba/sbin/nmbd -D
echo "OK"
stop() {
echo -n "Stopping samba: "
killall smbd nmbd
echo "OK"
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
restart|reload)
restart
echo "Usage: $0 {start|stop|restart}"
exit 1
esac
exit $?
best regards !
xiaocao
Postby MariuCh » Mon Oct 16, 2017 1:35 pm
xiaocao Wrote:hi ,
best regards !
Thank You very much.
What are "FTP tools"?
Regards,
MariuCh
MariuCh
Postby xiaocao » Tue Oct 17, 2017 11:04 am
hi ,
you can put S70smb file in usb flash . insert usb to moi+ ,it will auto mount in /mnt/usb dir .then copy S70smb to /etc/init.d/ dir.
#cp /mnt/usb/S70smb /etc/init.d/
#chmod 777 /etc/init.d/S70smb
best regards!
xiaocao
Return to MOI+
Users browsing this forum: Bing [Bot] and 1 guest
