usb problems
usb problems
Postby wifinederland » Sun Oct 02, 2016 3:27 pm
Hi i have in oscam reader 1 on /dev/ttyUSB0 it works good , but if my system is rebooted then it dont work anymore ,
if i check it with command ls /dev | grep tty then i se that it is change to /dev/ttyUSB1 and if i reboot again dan it is USB2
is it possible that i kan lock reader 1 on ttyUSB0 and reader 2 0n ttyUSB1
wifinederland
Re: usb problems
Postby zhangchao » Mon Oct 10, 2016 3:00 pm
there is also /dev/ttyUSB0 if reboot .
if change to /dev/ttyUSB1 , you should edit the file /usr/local/etc/oscam.server , change ttyUSB0 to ttyUSB1 or ttyUSB2 .
zhangchao
Return to MOI+
