moi+ update issue
moi+ update issue
Postby wynasoft1 » Sat Aug 27, 2016 1:40 am
im trying to use last moi+ version but after update sytem moi just frezz in message (system :0%) does anybody face same issue?
thanks a lot
regards
wynasoft1
Re: moi+ update issue
Postby ivx675 » Sat Aug 27, 2016 2:12 am
I updated some day ago, worked ok.
Formated fat32 sub, copied both update files to it.
Powered off MOI.
Attached USB.
Power On.
ivx675
Postby wynasoft1 » Sat Aug 27, 2016 9:07 am
update is ok but after update done and restart moi just stop at mio message so i have to swicth to old version and work perfect so i dont know what is the issue
thanks anyway
regards
wynasoft1
Postby wynasoft1 » Sun Aug 28, 2016 9:05 am
i just did a trick i update first system and then kernel and work perfect so if anyone have same issue that is the solution.
regards
wynasoft1
Return to MOI+
