Root password change
Postby MariuCh » Thu Aug 11, 2016 5:32 am
Is it possible to change root password without problems?
Regards,
MariuCh
MariuCh
Re: Root password change
Postby zhangchao » Thu Aug 11, 2016 11:31 am
1. ssh login to amd .
2. use command "passwd", it will tell you to input a new passwd.
[root@localhost media_build]# passwd
Changing password for user root.
New password:
BAD PASSWORD: The password is shorter than 8 characters
Retype new password:
passwd: all authentication tokens updated successfully.
zhangchao
Return to MOI+
