DVB-C usb stick no frontend was attached
Postby vblack » Mon Oct 14, 2013 11:24 pm
Hello, I have a problem with DVB-C usb stick.
First of all after following instructions I got nothing. Then I discovered that this is because according to lsusb I have:
Bus 001 Device 004: ID 734c:dc01 TBS Technologies China, whic does not supported by tbsdvbc.c, so I modified it to allow also dc01 device id for this driver.
After reboot I have more progress, it is found device in cold state, loads firmware, etc. But lsusb now reports that I have 734c:dc02 device.
Totally picture looks fine, except "no frontend was attached"
dmesg | grep -i dvb
[    6.778819] dvb-usb: found a 'TBS DVBC USB2.0' in cold state, will try to load a firmware
[    6.812363] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-dvbc.fw'
[    6.812380] tbsdvbc: start downloading TBSDVBC firmware
[    7.157063] dvb-usb: found a 'TBS DVBC USB2.0' in warm state.
[    7.161778] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[    7.162004] DVB: registering new adapter (TBS DVBC USB2.0)
[    7.901248] dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
[    7.935088] tbsdvbcfe: module license 'TurboSight Proprietary' taints kernel.
[    7.937213] tbsdvbcfe: attach failed : ff
[    7.937235] dvb-usb: no frontend was attached by 'TBS DVBC USB2.0'
[    7.939412] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:12.2/usb1/1-4/input/input7
[    7.939618] dvb-usb: schedule remote query interval to 150 msecs.
[    7.939629] dvb-usb: TBS DVBC USB2.0 successfully initialized and connected.
[    7.939764] usbcore: registered new interface driver tbsdvbc
Do you have any suggestions what need to be fixed?
I am using:
Ubuntu Server 13.04
Linux www 3.8.0-31-generic #46-Ubuntu SMP Tue Sep 10 20:03:44 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
Full logs:
dmesg_log http://pastebin.com/XktbpqMW
lspci_log: http://pastebin.com/rdfrQcHw
lsusb_log:
Bus 001 Device 004: ID 734c:dc02 TBS Technologies China
Bus 004 Device 002: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 004 Device 003: ID 046d:c05a Logitech, Inc. Optical Mouse M90
Bus 004 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 for Business
Bus 005 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
vblack
Re: DVB-C usb stick no frontend was attached
Postby vblack » Tue Oct 15, 2013 10:31 am
One small addition.
After device became "734c:dc02" it will survive system reboot, but on clean shutdown/wait/startup it will again become
"Bus 001 Device 004: ID 734c:dc01 TBS Technologies China" till firmware loaded...
vblack
Postby cody » Wed Oct 16, 2013 1:40 am
device with ID "dc01" is not supported in Linux - it's an old hardware for which you did not provide Linux support. so, there is nothing much that can be done - you need device with ID "dc02" in order to use it in Linux.
Postby vblack » Wed Oct 16, 2013 4:52 am
Anyway thank you for reply.
I will still try lo get it working under linux, because it is working fine on Windows for me, and I am developer. If you could just point me to some major differences between ID "dc01" and ID "dc02" - it would be great, if not - it is ok. :)
vblack
