[ Moderator Control Panel ]
by sparkey1000 » Sat Feb 13, 2016 5:16 am
Does anyone have the SW6 4 position switch settings for the TBS 2910 V2.3.
I am trying to boot from an SD card.
sparkey1000
by vpeter » Sat Feb 13, 2016 4:23 pm
I will be little malicious but you can have only 16 combinations with 4 pin dip switch right? So try one by one - it is few minutes work
vpeter
by sparkey1000 » Sun Feb 14, 2016 4:26 am
I thought of that. However, this 4 position switch may be used by the factory to load firmware into various sections of the unit. Some switch combination could result in the corrupting of an internal firmware load and turn this computer into a BRICK. Best to know what the 2^4 =16 switch combinations do before messing with them.
Regards
Sparkey1000
sparkey1000
by sparkey1000 » Sun Feb 14, 2016 4:29 am
I have a request into technical support for the schematic. They stated they are on holiday for a week and will get back to me after. We will see.
sparkey1000
Return to Install and setup
