TBS 6908 can't scan Thor 5/6 0.8W
Postby zkab » Wed Feb 04, 2015 12:33 am
I installed the drivers 'linux-tbs-drivers_150130.tar.bz2' according to the documentation for my TBS6908 card.
Installation went OK.
dmesg | grep -i TBS
[ 8.432304] TBS PCIE Detected TBS6908 Board Rev 3
[ 8.433476] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 8.595044] tbs6908fe: module license 'TurboSight Proprietary: http://www.tbsdtv.com' taints kernel.
[ 8.595178] TurboSight TBS 6908 Frontend Attaching...
[ 9.595734] TurboSight TBS6908 DVB-S2 card adapter0 MAC=00:22:ab:69:08:01
[ 9.595736] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[ 9.595773] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 9.595908] TurboSight TBS 6908 Frontend Attaching...
[ 9.598504] TurboSight TBS6908 DVB-S2 card adapter1 MAC=00:22:ab:69:08:02
[ 9.598505] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[ 9.598526] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 9.757506] TurboSight TBS 6908 Frontend Attaching...
[ 10.768223] TurboSight TBS6908 DVB-S2 card adapter2 MAC=00:22:ab:69:08:03
[ 10.768226] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[ 10.768331] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 10.768484] TurboSight TBS 6908 Frontend Attaching...
[ 10.771173] TurboSight TBS6908 DVB-S2 card adapter3 MAC=00:22:ab:69:08:04
[ 10.771175] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
But still I can't scan ... which I did without problems with my cheap testing tuner card Hauppauge 5500 before.
What is the problem ?
sudo w_scan -fs -c SE -s s0w8 -C UTF-8 -O 0 -R 0
trying 'S2 f = 10747 kHz H SR = 25000 3/4 0,35 8PSK'
(time: 00:11)
trying 'S2 f = 10747 kHz V SR = 25000 3/4 0,35 8PSK
ERROR: Sorry - i couldn't get any working frequency/transponder
Nothing to scan!!
zkab
Re: TBS 6908 can't scan Thor 5/6 0.8W
Postby smile » Mon Mar 02, 2015 4:12 pm
maybe your frequency seting wrong.I see the unit is "KHZ" not "MHZ",you may need to add three Zero.
Best Wishes
smile
Postby zkab » Mon Mar 02, 2015 4:22 pm
Yes - that was the problem.
Thanks.
zkab
Postby root » Tue Sep 29, 2015 10:14 am
my problem is similar and yet different, i get the error 'scan failed, please check the setting and re-start scan' i am trying to scan galaxy 19, 97'west, i have checked all my setting but just can't figure it out, i will really appreciate if anyone can help me , yes i am trying with a moi pro and a tbs6991se card
root
Postby steven » Wed Sep 30, 2015 6:06 pm
root Wrote:my problem is similar and yet different, i get the error 'scan failed, please check the setting and re-start scan' i am trying to scan galaxy 19, 97'west, i have checked all my setting but just can't figure it out, i will really appreciate if anyone can help me , yes i am trying with a moi pro and a tbs6991se card
Hi root
Please tell us your scan parameters we will have a check whether is right
kind Regards
Postby root » Thu Oct 15, 2015 12:33 am
hello steven, is there a way i can pm you cos i can't paste my parameters for some reason
root
Postby root » Thu Oct 15, 2015 12:58 am
HIGH BAND [MHZ]---10600
SWITCH BAND [MHZ]---11700
SWITCH PORT-------0
DISEQC VERSION-----DISEQC 1.0/2.0
DISEQC REPEATS-----0
SCAN SETTINGS
FREQUENCY[KHZ] - 12538000
SYMBOL RATE [SYMS]---41250000
POLARISATION---H
DEVILERY SYSTEM----DVBS
CONSTELLATION-----QPSK
FEC---1/2
i am hoping this helps, thank you all for your time and support
root
Postby steven » Fri Oct 16, 2015 6:19 pm
Hi root
Please send your detail parameters to our support#tbsdtv.com we will have a check
kind regards
Postby root » Tue Nov 03, 2015 3:48 am
i have tried to contact support#tbsdtv.com with no luck, after filling in everything i am ask to enter the captcha , i did and still get same thing, i captcha is usually numbers like 2+3=?, i wrote the same it didnot work, i answered the question it did not work, it very frustrating
root
Postby stilmant » Thu Nov 05, 2015 12:44 am
@root
don't use the contact support page, you can send direct email like explained here:
viewtopic.php?f=165&t=2194
stilmant
Return to Install and setup
