sound output HDMI + SPDIF + Jack simultaneously
Postby laruf » Thu Oct 23, 2014 5:32 pm
I wonder if it's possible to get audio output simultanously on HDMI, SPDIF and jack output device ?
Regards
laruf
Re: sound output HDMI + SPDIF + Jack simultaneously
Postby mikebzh44 » Thu Oct 23, 2014 9:32 pm
There is a patch :
http://forum.xbmc.org/showthread.php?tid=192480
But this patch need to be merged in MatrixTV and/or OpenELEC for Matrix and XBMC need to be recompiled.
mikebzh44
Postby laruf » Sat Oct 25, 2014 5:39 am
Thanks mikebzh44, but i'm not sure i can be able to do that. If you got any howto i will try, but i don't have enough knowledge to proceed on that.
Otherwise searching to the internet, i've found this : http://forum.xbmc.org/showthread.php?tid=145430, which could help me. The problem is that (connected thru ssh in root in OpenElec) i can't modify any file. Always got a "read-only file system" message and can't modify or create any file.
Any idea on how to solve that ?
laruf
Postby mikebzh44 » Sun Oct 26, 2014 3:49 pm
laruf Wrote:Thanks mikebzh44, but i'm not sure i can be able to do that. If you got any howto i will try, but i don't have enough knowledge to proceed on that.[]/quote
Sorry I'm not able to did it either :(
Are you sure to edit right files because it's mentionned :
/storage/.config/asound.conf
/storage/.xbmc/userdata/advancedsettings.xml
And those files are in your user space so you can edit them.
mikebzh44
Postby vpeter » Sun Oct 26, 2014 4:23 pm
I don't think asound.conf trick works anymore because XBMC uses audio output directly.
vpeter
Postby laruf » Mon Oct 27, 2014 3:47 am
@mikebzh44
You're right, i wasn't try to edit the correct files (tried to edit in /etc directory). So I tried in /storage/.config and /storage/.xbmc and then can create/modify these files, but that haven't resolved the problem. But it seems to work with others...
@vpeter
Means you may be right: asound.conf isn't use anymore. The only away should be to recompil XBMC with the patch you've talked about...
laruf
Postby laruf » Sun Nov 02, 2014 6:47 am
Hi all,
Who could help me or give me an howto recompil XBMC with the patch mention above by vpeter ?
Thanks for your help
laruf
Return to Install and setup
