Problem on Matrix TBS2910 platform out of the box
Postby laruf » Wed Oct 22, 2014 8:35 pm
I've just bought a Matrix TBS2910 and face a problem with it.
I've only get it out of the box and connect it in hdmi to my tv. I only use XBMC and the video is ok, but there's no sound : None with HDMI, or SPDIF ou jack output.
Thank in advance for your help to solve this issue.
laruf
Re: Problem on Matrix TBS2910 platform out of the box
Postby vpeter » Wed Oct 22, 2014 9:08 pm
Did you set correct audio output in xbmc settings?
vpeter
Postby laruf » Wed Oct 22, 2014 10:58 pm
I can't modify the output audio device (the selection is in grey). I suppose that it's the default one.
I can only change 2.0 or 2.1 or 5.1 or 7.1...
laruf
Postby vpeter » Thu Oct 23, 2014 1:09 am
laruf Wrote:I can't modify the output audio device (the selection is in grey).
Then I don't know. In openelec I can choose different types of output.
vpeter
Postby laruf » Thu Oct 23, 2014 4:09 am
Thanks for your feed back.
For those who can help i only have "Default (sgtl5000-audio Analog)" as output audio device. And can't change it.
I also try to flash my Matrix box with the latest MatrixTV firmware using this viewtopic.php?f=155&t=8990#p32069 but also it don't works (i switch in boot mode and update mode also)
Anyone who could help ?
laruf
Postby mikebzh44 » Thu Oct 23, 2014 1:23 pm
Did you press any key when MatrixTV splash screen is displayed, to enter configuration setup and choose which device to use for audio output ?
mikebzh44
Postby laruf » Thu Oct 23, 2014 5:29 pm
No i didn't.
I've made like vpeter and switch to Openelec. I've now get sound on HDMI interface. But not in SPDIF even if i select SPDIF device in xbmc audio configuration settings. I need to have sound output HDMI + SPDIF simultaneously. Should open an other topic for that...
I could stay with Openelec, but face other problem with fast forward when watching a video (fast rewind works well). Should open an other topic for that...
It's a work around, but still an issue on XBMC on MatrixTV.
laruf
Return to Install and setup
