Upgrade from SD card : where are the files needed ???
Postby mikebzh44 » Thu Oct 09, 2014 12:52 pm
Hi.
I'm just trying to upgrade my MatrixTV v1.3 to 1.0.1.0 but I can't find files listed on PDF to upgrade via SD card :
http://www.tbsdtv.com/download/document ... e-V2.1.pdf
I have downloaded :
http://sourceforge.net/projects/matrixt ... p/download
and
but when I extract it, I can't find :
* rootfs-m.tar.bz2 (there is a rootfs.tar.bz2 in Profiles\MX6Q Linux Update\OS Firmware\files
* uImage-m (only uImage is available in Profiles\MX6Q Linux Update\OS Firmware\files)
* uramdisk (no file at all)
So your PDF is not up to date ? Whate is the correct way to upgrade MatrixTV V1.3 by SD card ?
Thanks.
mikebzh44
Re: Upgrade from SD card : where are the files needed ???
Postby mikebzh44 » Thu Oct 09, 2014 1:07 pm
BTW, I'm trying to upgrade by flashing the new release.
I switch from Run to Burn, plug MatrixTV to my PC (running Windows 8.1 64 bits) and power up MatrixTV but no device detected. Did I have to install some drivers ?
And in your PDF : http://www.tbsdtv.com/download/document ... e-V2.1.pdf
What is the difference between "switch to another operating system" and "How to burn a new OS on eMMC on Matrix" ?
Because I don't have any Boot / Update switch.
mikebzh44
Postby vpeter » Thu Oct 09, 2014 2:28 pm
vpeter
Postby mikebzh44 » Thu Oct 09, 2014 3:24 pm
Thanks.
I think that PDF need a little update :D
mikebzh44
Return to Install and setup
