Raspbian or similar?
Postby rossi46 » Wed Aug 27, 2014 3:53 pm
Can I burn the Debian - based Raspbian os onto my new Matrix?
If not, what are my choices as far as Linux distros are concerned?
I don't like the Unity desktop :)
rossi46
Re: Raspbian or similar?
Postby diabloss » Sun Aug 31, 2014 2:09 pm
not yet but soon.
Openelec might be a good choice also
diabloss
Postby AlbertKy » Sun Aug 31, 2014 3:12 pm
rossi46, you can install lxde or xfce.
My way was:
- Open a terminal
- sudo apt-get install synaptic
- open synaptic
- search for xfce
- select the xfce meta package an install it.
- click the "power button" at upper right corner - select restart. You will land in a login screen
- in loginscreen is a small arrow, there you can select your preferred Desktop.
- log in and enjoy.
Unfortunately there is no Mate-Desktop.
Greetings,
Albert
AlbertKy
Postby rossi46 » Sun Aug 31, 2014 8:23 pm
@AlberKy, thankyou, I'll give that a go!
Btw, before I purchased my Matrix board, I ummed and awwed of ages before deciding on my purchase. It was the "Install any OS you like" blurb on the homepage that gave me the final push :cry:
rossi46
Return to Install and setup
