Update via SD Card
Update via SD Card
Postby SinOjos » Sat Aug 09, 2014 11:05 am
To update to the latest Matrix OS version via sd card, the docs state 4 files are needed.
uramdisk.img
uImage
uImage-m
rootfs-m.tar.bz2
I have downloaded the recent release, but 3 of the listed 4 files do not exist.
uramdisk.img
ulmage-m
rootfs-m.tar.bz2
There is a rootfs.tar.bz2 which I am assuming is the the file to use and since there is no uImage-m the rootfs-m.tar.bz2 would go with that, therefore the rootfs.tar.bz2 should be used.
I want to clarify that to do an update, are only 2 files necessary?
uImage
rootfs.tar.bz2
Also, why are the tools windblows only? Many people do not use m$ at all, in fact they only have a 14% world wide market percentage. I do not use windows or mac, Linux only. Why wasn't the tools built utilizing something like python or java which is NOT OS specific?
Your website claims 100% open source, yet you only provide tools that work with closed source. That is misleading to say the least.
SinOjos
Re: Update via SD Card
Postby franky384 » Tue Sep 02, 2014 12:51 am
+1
I also want to know how updating via SD-card works. I tried several files but nothing works !!!
But i think here is no one that matters about the problems of the users that spend the money for tbs-products !
Shame on ts.
franky384
Return to Install and setup
